May 22, 2018, 06:42:43 PM *
Author Topic: Water heater misbehaving  (Read 1513 times)
jjrbus
MCI5C/N Ft Myers FL
« on: October 29, 2007, 04:12:11 PM »
 I have a Suburban 6 gal, SW6DE electronic ignition, LP/Electric water heater. When useing hot water the tank operates fine. If the tank sets unused, say overnite, it runs out of hot water quickly. it will then ignite and heat the water like it is suppose to do. This is all on LP. I only use the electric when I am somewhere I am not paying for the electric, like at Jacks house Grin
Utahclaimjumper
« Reply #1 on: October 29, 2007, 05:19:41 PM »
So whats your problem??>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
jjrbus
MCI5C/N Ft Myers FL
« Reply #2 on: October 29, 2007, 05:53:25 PM »
 The heater does not maintaine water tempature?
niles500
Niles500
ROSIE
« Reply #3 on: October 29, 2007, 06:26:51 PM »
Sounds like (if your talking overnite as being on shore power/electric) your element is burned out or wire is burned through or switch has malfunctioned - HTH
(\__/)
(")_(")
- Niles
Utahclaimjumper
« Reply #4 on: October 29, 2007, 07:25:21 PM »
At best it sounds like the temp bulb has too much 'swing', it needs COLD water to trip, I wonder if the temp sensor could be replaced.>>>Dan
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
Paladin
Dave Knight
« Reply #5 on: October 29, 2007, 07:31:33 PM »
Sorry to butt in,
Dan, do you know Bob Sather down there?
-Dave
'75 MC-8   'Event Horizon'
8V71  HT740
Salt Lake City, Utah
Sojourner
« Reply #6 on: October 29, 2007, 08:48:08 PM »
Sound like your heater's automatic low limit switch or turn-on setting is too low or sticky.....need a bigger hammer or replace thermostat control valve.
Wish you well!
FWIW
Sojourn for Christ, Jerry
Utahclaimjumper
« Reply #7 on: October 30, 2007, 05:37:12 AM »
Dave, dont know Bob, should I ??>>>Dan
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
superpickle
« Reply #8 on: October 30, 2007, 07:26:35 AM »
Pull it out, Cut the top off and Plant a Tomatoe in it  Grin
then get a Tankless system..  Grin
Maroon..  Tongue
Support Global Warming:
Drive an SUV.
