May 18, 2013, 10:57:26 AM *
Author Topic: Zimtok is a Super Shifter!  (Read 2076 times)
« Reply #15 on: November 05, 2007, 03:34:55 PM »
OK,
My video is not perfect.
Tiptoes: I was trying to keep my right leg out of the way to show my left leg on the clutch pedal.
Foot on clutch: I have no excuse. but I will say that i do not put pressure on the pedal.
Cruise: I like the pedal lock, and I have no problem setting it for any speed (usually full throttle) and if I hav eto make a quick stop I just push in the clutch and hit the brake. The engine can stay at high idle until I can release the lock.
Zimtok I thought the video was awesome! But I did learn many, many years ago that by merely "resting" your foot on the pedal not intentionally applying pressure. That even though you aren't meaning/intending too, but you are actually applying a very slight pressure which is sometimes just enough to make the throw out bearing ride the fingers of the pressure plate which causes premature throw out bearing failure! FWIW Grin  BK  Grin
