February 25, 2018, 06:04:20 AM *
Author Topic: Be Careful When Grinding.  (Read 4973 times)
Lee Bradley
« Reply #15 on: November 06, 2007, 08:45:11 AM »
For what it is worth, I use a heavy duty air hammer with sharp chisel to remove those unmoval nuts. Just cut the nut from the side or top. The chisel will cut the nut and expand it away from the threads. I use this quite often on exhaust nuts on studs and can generally reuse the stud after chasing the threads.
lyndon
1988 MC-9 DDC 6V92TA Fuller T-11605D
« Reply #16 on: November 06, 2007, 10:16:09 PM »
I also have a 2 gallon garden pump up canister of water at all times which has about a 18 inch wand on it to get into tight areas such as Dallas experienced and I have also in the past.  If you see a smoldering area you can normally pump in enough water using your garden pump to extinguish most smoldering debris without going into a panic and looking for a fire extinguisher or water hose which may be too late with as fast as this stuff used for floor insulation ignites.
Gary, thank you for the great safety tips. The garden pump idea is simple and makes so much sense, I'm going to buy one tomorrow. I once had a trailer brake dragging and the drum literally got red hot. After stopping, flames broke out and we emptied 4 or 5 dry fire extinguishers on it. Finally, somebody dragged a pail of water from the ditch and cooled the drum enough to stop the flareups. I didn't even think about having water ready until your post.
Just for fun, here's a photo of me breaking most of the rules just a couple of weeks ago. (At least I was wearing goggles...) This, of course, after breaking several drill bits.
Don
1988 MC-9
lyndon
« Reply #17 on: November 06, 2007, 10:26:03 PM »
Lee, that makes a lot of sense to me. Do you ever find the need to use a cutting wheel?
Don
Don
1988 MC-9
« Reply #18 on: November 07, 2007, 12:52:25 AM »
I also had a smoldering insulation problem, happened when I cut off the seat brackets on our Eagle. I quickly put it out but it caused me to be more careful.
One thought on anyone welding, grinding and such can cover the are with a welding blanket, available at most welding supply houses, Grainger and Mc-Master Carr. I have used these over the years in my line of work and they work great. Just another way to protect yourself and your investment.
Gary LaBombard
"Rustless Money Pit"
« Reply #19 on: November 07, 2007, 06:15:28 AM »
Lyndon,
I just cringed when I saw your posted photo but again I too have done things many times and sometimes still take chances but much less now.  You are right, you were breaking many safety suggestions there but the safety glasses had to help.  I see your clothes taking a beating and those bare arms, on my!!  Use a little more care in your set up so pieces that you cut off are not being balanced on your leg like that, but injuries make you realize this more so be careful.
Paul, the welding blanket is a great idea, I have burned through one so far from just GRINDING sparks and some welding.  Once a very small hole goes through these blankets it is a great spot for enlarging and smoldering from hot sparks but it will still protect right up until it is no longer any good.  One blanket badly spent in 4 years now is not bad, the new one I have has lasted over a year now and no holes so far.  A 6 X 6 foot blanket is about $20, and very cheap insurance and will surely help prevent a fire on your bus.
NOTE!!  The use of Cutting wheels on grinders requires more care when being used.  They are very thin as some are (.046 -.125) in thickness varying between uses and manufacturers.  The important thing to remember is there is very little flexibility using these cutting wheels, if you have a tendency to lean to the side when using it the wheel could easily bind up in on millionth of a second and split apart and make you wish you had safety glasses with side shields on and if possible a full face shield.   Not wearing welding gloves using a cutting wheel or any grinding wheel also is not advised, these wheels turn up to 10,000 rpm and can cut metal and when doing the same rpm when they fly apart can sure cut your face or arms really bad.
I have had a grinder with a cutting wheel kick up many, many times and sometimes kick so bad it would hit my left hand as I would be in a very difficult area to work in and the grinder hit my left hand many times.  I have gone through over a dozen left hand welding gloves from being hit with the cutting wheels over time.  Thats 12 left hand gloves that saved me from probably 100 serious accidents especially to my thumb area.
Here is a thought also when using the cutting and grinder wheels.  I have had to use my grinder maybe 10 inches from my face in positions that made it impossible to do any other way.  My thoughts ever time I have to do that make me intense, nervous and so anxious to get that operation done every time I do it.  I hold on my grinder with the strongest grip possible to prevent this cutting wheel or grinder wheel from getting me in the face.  You have no earthly idea how nerving this can be.  One mistake and I am carved up very seriously and for life and my conversion would probably end right there if this ever happened.  There is no second chances when this happens and you cannot react fast enough to prevent it when it happens.  Just keep this vision in your mind Lyndon and anyone else needing to use their grinder.  It is nearly like thinking of your grinder as a loaded gun with one bullet in it.  Using a grinder is nearly like playing Russian Roulette.
Dallas, a lot of good ideas come out of this post.  Use as much care as you all can on your buses, lets all meet at one of our great rallies, safely and with all limbs and eyes.
Gary
Gary
Lee Bradley
« Reply #20 on: November 07, 2007, 08:50:20 AM »
Don
The only cutting wheel I have is a 14" chop saw. I also have angle grinders that can cause these same probems.
NEWELL in South Carolina
« Reply #21 on: November 07, 2007, 10:01:17 AM »
. . . . cannot wear short sleeved shirts comfortably.  The reason, my arm always looks real dirty in the front of the elbow areas of my arms, not real perty to look at.
Awww, come on Gary. If we all had to live to that standard, we wouldn't know what most of us looked like  Grin
Paladin
Dave Knight
« Reply #22 on: November 07, 2007, 10:13:06 AM »
You guys have me paranoid now. I was doing some grinding yesterday and although I have no insulation or wood there might still be junk down in crevices.  I keep one of those fire extinguishers that you can charge with water and air nearby whenever I weld or grind. You know, the ones we used to spray out of cars at people when we were teenagers? Not me though!!!
Anyway I kept going out there late at night last night worrying that there might be something smoldering. Especially since I had been painting my plywood with clear coat inside the bus. I envisioned my bus going up in flames while I was asleep taking my cars and house along with it.
While grinding welds on my trailer a buddy of mine caught my shirt on fire with his sparks from grinding behind me. With the respirator and goggles on I didn't notice until I saw smoke rising up. Nice guy!
« Last Edit: November 07, 2007, 10:14:54 AM by Paladin » Logged
'75 MC-8   'Event Horizon'
8V71  HT740
Salt Lake City, Utah
Gary LaBombard
« Reply #23 on: November 07, 2007, 10:52:09 AM »
Paladin,
This thread may cause you a little paranoia but it will be worth it if it saves your bus by exercising a little safety.
After working on my bus for any length of time and storing all my tools used I have the habit to get me a comfortable chair, a soft drink or what ever beverage you want and just sit there with all working equipment (welder included) shut off except for lights I use to see.  I will sit there about 30 minutes and listen, view what I have accomplished or didn't accomplish and plan on my next task the next day but it gives me an opportunity to smell and listen for anything out of the ordinary.  Oh, Be sure to shut off or unplug your air hose if you used one to quiet any air leaks that may confuse your hearing for something else you may overlook.
Usually after this length of time smoldering smoke will appear by sight or smell, but using a welding blanket or shield to prevent hot sparks from flying around and igniting anything combustible will sure help prevent a serious fire.
When you are done at the end of the day, don't just close up shop and go in the house, always assume you forgot something and stay around a while to be sure you didn't.  We are always in a hurry to get to work, hurry to get done and hurry to get in the shower.  A little rest for security of your shop before the shower will keep your bus and property safe.
Good luck,
Gary
Gary
DavidInWilmNC
« Reply #24 on: November 07, 2007, 11:05:53 AM »
One thing I've found that's helped grinding (with a hand-held angle grinder) is to use a 7" instead of a 4" grinder, when possible.  I bought a somewhat raggedy Makita for $20 from one of my favorite pawn shops.  It's quite a bit heavier, but tends to be less prone to kicking and moving about than my smaller ones.  I'm not sure if it's the fact that the wheel is turning slower (although the actual inches per second of the grinding surface is likely the same) or the weight of the tool that makes it seem easier to control.  I've found, for lots of tasks, a 25 grit disc on a rubber flap wheel attachment works as well as a grinding disc for removing rust and grinding down steel.  I've made holes right through some relatively thin floor frame on my MC-8 with it, so it'd definitely capable of doing the trick.  Plus, a flying piece of sand paper hurts a lot less than a broken grinding disc (although I've not had one break).
The worst injury I've inflicted on myself was a grinder with one of those metal brush wheels.  Of course, they throw out metal bristles occasionally, so goggles are imperative.  I generally wear gloves, too, but this one time I didn't.  I was removing some surface rust from a piece of steel about 24" long.  I was holding the piece in my left hand about 6" from the left end and working on the extreme right end... far enough from my hand to not need gloves, right?  Hardly!  The wheel 'walked' up the piece I was working on and hit two knuckles on my left had after I'd let go of the trigger on the grinder.  It wasn't spinning at it's usual 12,000 rpm, but it still took out an approx. 1 long chunk of skin.  It' taken about a month for it to heal completely... and it hurt like hell!  I don't know that I'd trust welding gloves for this, as the ones I have are very soft and comfortable.  I have some fairly long thick leather gloves that I use with grinders and such.
One tool that I've found to be almost indispensable is a plasma cutter.  I know a good one's expensive, but if you can rent or borrow one, it'll make a lot of jobs easier.  Cutting out the rusty floor supports as shown in this thread www.busconversions.com/bbs/index.php?topic=6278.09 would take no time with a plasma cutter.  Of course, it's no substitute for safety precautions... mainly from the possibility of a fire, but I've not had any issues with it yet.  I guess I'd describe it as a combination of grinder and welder, in terms of how one needs to think of safety.  The fact that it's so easy to maneuver and so fast to cut helps, too.
Those times where I'm only going to be using the tool for a few seconds to a couple of minutes are the times I want to forgo the gloves, goggles, and ear plugs... and those are the only times I ever get hurt.
David
Hartley
« Reply #25 on: November 07, 2007, 07:18:47 PM »
I know this thread is about grinding, cutting and welding, However...
Safety Warnings ;
In one of those moments of clarity, I need to mention something that has not been talked about in quite some time on the boards.
Spray Foam is Flammable....In any shape..
Beware of using spray foam or foam in a can because it's propellant may contain butane/propane or some other highly flammable gases and the gases that are generated can get encapsulated in the foam as bubbles. The gas can also settle into lower areas which can create potentials for fire or explosions.
Always have plenty of ventilation when using foams. Never allow sparks, chips or excessive heat to contact the foam surface, It will burn and burn rapidly.
This also applies to foam insulation boards, all types are flammable and can decompose with heat into some nasty fumes which are poisonous.
All foam insulation board is required to be covered by a fire resistant material, Never left exposed on any surfaces. ( By Law and Building Codes ).. I know we all stretch that one since conversions are more difficult to use approved materials sometimes in the way they were specified.
The same care should be used when cutting around freon lines. Open flames and freon generate toxic gases. Used to be Phosgene (poison) but many different chemical reactions can still happen even with the newer refrigerants.
CO and SMOKE detectors should be installed in all RV's and Bus Conversions even while under construction you should have a couple nearby just in case.
Water based or CO2 based fire extinguishers should always be ready and on hand.
( See RVSafety Systems for a water based solution that works! )
A garden sprayer at the ready is very useful and makes a nice safety device.
Don't use the dry powder fire extinguishers. You will never get that corrosive powder out of your work area if you do. It should only be a last resort... If that stuff gets wet and is against aluminum or steel it will cause nasty corrosion.
Sorry, I know I drifted off there but it is better to rant about safety BEFORE someone gets hurt or loses their life savings....
Dave.....
msheldon
1954 GMC PD4501-066 8v71TA
« Reply #26 on: November 07, 2007, 09:09:52 PM »
OK, am I the only one who read the subject and thought "geez, does everyone know how bad my shifting is?"  Grin
lyndon
« Reply #27 on: November 07, 2007, 09:48:43 PM »
Do sparks fly from your transmission?
Don
1988 MC-9
msheldon
« Reply #28 on: November 07, 2007, 11:23:43 PM »
I'm afraid to look.
Got it stuck in third at a light and had to pull out that way once. Smoked the clutch real good. One of the linkage bushings needs replacing.
This thread has been a good reminder to me though. I will soon be doing some grinding work myself.
Hartley
« Reply #29 on: November 08, 2007, 05:28:38 AM »
OK, I give?Huh
How did a persons bad shifting habits get involved in "Grinding"?
We don't talk about gear grinding... Roll Eyes Roll Eyes Roll Eyes Roll Eyes
That is a whole other painful subject.... Grin Grin
