May 22, 2013, 02:06:23 PM *
Author Topic: What fluid does Ross power steering use?  (Read 851 times)
NCbob
« on: May 26, 2006, 01:43:40 PM »
Checking out my bus today and repaired the blower sight glass.  Which prompted me to check the rest of the fluids.  My MC5A has retrofitted Ross power steering and it appears the sight glass is MT!  Angry
Do any of the more astute among you know what would be the proper fluid to bring it up to level?  Smiley
Normally, I would use power steering fluid, but in this case, just in case it's hydraulic oil... Embarrassed  I thought I'd better check it out.
NCbob
« Last Edit: May 26, 2006, 02:01:05 PM by NCbob » Logged
« Reply #1 on: May 26, 2006, 07:02:49 PM »
Hi Bob,
If it's red, its Dexron.  If it's brown, it's 10W30 motor oil.  MCI used both.  Pull the cover off the res and see what color the oil is.   You can tell by the smell too.  Automatic trans fluid stinks.  Motor oil doesn't.
You don't want to mix them, but either works fine.
Best, JR
