April 24, 2018, 11:31:51 AM *
Author Topic: Useful part  (Read 6056 times)
« on: December 09, 2007, 06:23:13 PM »
For some reason the MC-5a I just got did not have a dash high beam indicator light, so I wired to install one.  I was having trouble finding an acceptable 24 volt light to use and I've had a 12 volt one around for years.  I don't know about you guys, but if I can use something I've had around for 20+ years, even if it's a dollar part, I feel good about it.  It sort of justifies saving all the junk I have.  Anyway, Radio Shack has a $1.50 part they call a "voltage regulator" that reduces any input up to (I think) 50 volts down to 12v.  I just installed it and it works so far.  Seems to me that it could be a useful part around the bus.  Only problem is that it is rated up to 1 amp.  I don't know if they have higher rated ones.
prevost82
82 Prevost 8V92ta 6 speed
82 Prevost Marathon XL
« Reply #1 on: December 09, 2007, 06:33:28 PM »
Most automotive store (NAPA) will have 24V to 12V converter.
« Reply #2 on: December 09, 2007, 07:07:32 PM »
Am I right in guessing that a 24v to 12v converter is a small step-down transformer?  This "Voltage Regulator" part is only about 1/2 square not including the leads.  This one is only good for one, tiny dedicate application.  I am guessing the 24/12 converter you mention is bigger, but can be used for a bit more serious labor.
« Reply #3 on: December 09, 2007, 07:26:54 PM »
Lin,
An easy to go down to 12v from 24v is to wire two 12v bulbs in series. You can't use two bulbs is some applications but you can in most.
Brassman
« Reply #4 on: December 09, 2007, 07:31:28 PM »
One simple part to drop the voltage is a resistor. That is why somebody previously said to put put two 12 volt lamps in series.
« Reply #5 on: December 09, 2007, 07:58:32 PM »
Actually, I went to Radio Shack to buy a resistor for this.  I do not know much about them, and the salesperson did not seem to able to tell me which one I needed.  This part works with different voltage inputs but outputs my beloved 12v, so I got it.  Like a resistor it has an input and output lead, but it has a third going to ground.  No big deal, but something that is useful for the right app.
« Reply #6 on: December 09, 2007, 08:29:26 PM »
For the same $1.50, you could have purchased an LED, mount, and resistor and wired that into 24v, and never had to change
it again.
If you had the opportunity to salvage one from an old computer or electronics item, it would have only cost you the resistor and maybe the mount.
If you'd posted here first, I'd have mailed you a couple LEDs and resistors for free. You'd still have to buy a mount, though.
« Reply #7 on: December 09, 2007, 09:49:29 PM »
Oh well, the LED's would have been better, but I wouldn't have had the pleasure of using the light I've had in a parts box for over 20 years.  However, I completely expect that it will fail soon, and I will ask you about the LED's then.  Maybe it will fit in this fixture.  Thanks
« Reply #8 on: December 10, 2007, 05:11:29 AM »
I've converted most of my dash lights and tell tale lights to led by breaking out the glass from the old bulb and soldering in a resistor
and led in the old metal bulb housing. No wiring changes needed. Some Tell tale lights can't be converted because the circuit needs the bulb's
resistance to make it work.
Slow Rider
« Reply #9 on: December 10, 2007, 05:31:25 AM »
Gumpy,
Please school me.  If you are putting a resistor in line with the led anyway, why can't you match the resistance the bulb would have provided?  Expiring minds want to know........
Frank
Yes I am a BUSNUT
1976 MCI MC8
MCI Courier
« Reply #10 on: December 10, 2007, 06:28:26 AM »
Hi Lin,
 On my MCI Courier, that small light in the centre of the cluster of warning lights is my high beam indicator. I'm pretty sure that it's original as I haven't seen any other place for one.
Pete
tekebird
« Reply #11 on: December 10, 2007, 06:29:44 AM »
It should have one stock....bulb is probably just out
tekebird
« Reply #12 on: December 10, 2007, 06:30:26 AM »
check your maint. parts or operators manual for location
« Reply #13 on: December 10, 2007, 07:44:36 AM »
I use to have a useful part, but Cat says I don't anymore.
DavidInWilmNC
« Reply #14 on: December 10, 2007, 08:28:43 AM »
Well, you know what they say about 'use it or lose it'...
