I may take the advice of others on this board, and remove the sutrak unit off the coach entirely. That being said, I am going to be installing a generator. I know where that is going to go, but I have a question.
since I am removing the AC compressor from the passenger side of the bus, it is going to leave me a ton of room. I was thinking about putting a plastic fuel tak where that was, and simply run a fuel line up to the generator, with a small electric pump too, I'm sure.
Is this legal to have a gasoline tank so close to the diesel engine? I was thinking a nice small 15 gallon tank or so, just enough to run it.
the other thought was a small tank like from a chevy astro, long and narrow 17 gallon, and just use that under the coach someplace, if there is room...
any thoughts?
shawn
Fuel tanks should not be forward of the front axles or behind the rear axles for safety reasons. I would not place a Gasoline tank
anywhere near to the bus engine for any reason. Just asking for burn-down problems and potentially explosive results.
Find some place safe and away from moving or hot parts, away from where shedding a tire will not impact the tank. BOOM !
