April 21, 2018, 04:51:18 AM *
Author Topic: correct oil level in a 8V71 (T-drive)  (Read 4672 times)
« Reply #15 on: July 10, 2013, 08:31:11 AM »
A DD oil cooler doesn't dump oil back into the pan the oil galleys are always full unless the valve is bad inside the pan on the block,this is one reason the oil turns black in hurry there is no way to drain it all
