February 23, 2018, 10:44:04 AM *
Author Topic: What amperage to charge a dead 8d?  (Read 3455 times)
mike davis
« Reply #15 on: February 01, 2008, 02:56:44 PM »
The digital charger that I bought has a charge percentage of the battery and a voltage.  Both batteries charged up to 64% within an hour or so.  But it took the last 6 hours to get them to 67%.  Any idea on what could cause this?
I'll give you some math
 Each cell in the battery charges to 2.1-2.3 volts So a fully charged battery is some where between 12.5 to 13 volts All electrical equipment has a +/- 10% tolerance built into it  If it is designed to run on 10v it is designed to run without any loss  of preforming between 9-11 v It might make a little heat dew to resistants
 so if 12.5 V. is charged Your battery is somewhere between 8-9??? v. now But that does not tell you the state of the batterys capacitances (I think that is the right word It has been 25 years since i got out of collage For H,V,A/C )
  mike
TrevorH
« Reply #16 on: February 01, 2008, 03:39:03 PM »
I am pretty sure there are 8 cells so using your voltage that would put the battery at 16+ volts.  Is this correct?
Tucson, AZ
« Reply #17 on: February 01, 2008, 03:47:11 PM »
12 volt battery has 6 cells (each battery cap is a cell)  2.1-2.3 X 6 cells = 12.6-13.8 volts
 6 volt batteries have 3 cells 2.1-2.3 X 3 cells = 6.3-6.9 volts  Jack
mike davis
« Reply #18 on: February 01, 2008, 05:22:18 PM »
jack
       your right
                    I through some "field math" in it. I should explained that If your getting between 12.5-13V. The battery is ok, not new but ok for voltage But that does not tell the hole story of the battery
                              thank you
                                             mike
Reddog
1990 Thomas "Hormone Derange" Gunnison, Colorado
1990 Thomas Transitliner, 8.3 Cummins/Allison Auto
« Reply #19 on: February 01, 2008, 05:23:28 PM »
I would think that the 60% (+/-) that the charger shows is a percent of the batteries storage capacity, not necessarialy the voltage. i have seen lots of batteries that have 12-13 volts, but not enough reserve amps to light the headlights, much less turn the engine. Doug
"If people don't stare and point as you drive by, keep working."
