April 24, 2018, 07:57:18 AM *
Author Topic: Onan Marquis 7000 Generator Problems  (Read 5989 times)
Fred Mc
« on: February 02, 2008, 08:38:48 PM »
I just bought an Onan Marquis 7000 generator. Apparently the motor works fine but it is not putting out any AC.
It was hooked up to a remote which is missing so I need a manual that has electric schematics so I can start the thing and try and figure out what the problem is.
Anyone know where there are free manuals for download? Any other help would be appreciated.
Fred Mc.
« Reply #1 on: February 03, 2008, 05:26:20 AM »
I downloaded manuals for an older Onan several years ago by googling ONAN MANUAL.  When I sold that generator, the manual went with it and do not remember where I got the manual.  Jack
« Reply #2 on: February 03, 2008, 05:29:41 AM »
I have seen Onan manuals on eBay at times.
HTH
« Reply #3 on: February 03, 2008, 06:08:14 AM »
From the Board Help board under Favorites, reply 4, http://www.busconversions.com/bbs/index.php?topic=3071.0:
http://asavage.dyndns.org/Onan/display1.php?Path=900-0337&db=Onan&table=900_0337&Page=019
http://users.california.com/~eagle/list.html#GEN
http://www.smokstak.com/forum/archive/index.php?f-1.html
http://www.gmcws.org/Tech/onan_electronic_ignition/onan_electronic_ignition.html
http://www.gmcws.org/Tech/dsimmons/onan/onan.html
http://www.funroads.com/onanstore/osHome.jhtml
http://www.perr.com/onan.html
« Last Edit: February 03, 2008, 07:08:46 AM by DrivingMissLazy » Logged
NCbob
"Foolish Pleasure" 35' MC5A
« Reply #4 on: February 03, 2008, 07:27:31 AM »
Fred, first check to make sure the output circuit breaker is closed. Most of these failures are due to a bad voltage regulator. Onan wants way too much for them so I recommend Flightsystems.com for a quality replacement.  I helped them design and prototype their Onan replacement regulators so I know from whence I speak.
Good Luck.
Bob
orfunauto/Darrell
« Reply #5 on: February 03, 2008, 06:08:20 PM »
This may not be the fix for your problem, but I had a no output condition with my 7000 this past summer.  It was intermittent, and what I found was a wire had backed out of the multi-pin connector in the circuit breaker box.  I spread the retaining clip on the barrel connector for that wire, pushed it back into the main connector, and have not had a problem since.  Hope your problem is as simple!
74 MCI 8
LaGrange, NC
