January 17, 2018, 04:20:22 PM *
Author Topic: Xantrex Freedom 458 inverters, two or more in series?  (Read 2539 times)
grantgoold
« on: February 02, 2008, 10:21:07 PM »
Has anyone placed two Xantrex Freedom 458 inverter side by side or in a series? I cannot find in the manual how to put two inverters together to boost the output. I am trying to avoid having to get a second switch, fuse and battery system.
I already have one Xantrex Freedom in the bus with five 220 amp hour batterires but have a chance to get another inverter just like mine.
Ideas of how I can place the second inverter into the system or do I have to get a second set of batteries......
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
« Reply #1 on: February 02, 2008, 10:48:35 PM »
Hi Grant,
I couldn't find any stacking options/configurations in your installation manual.
http://www.xantrex.com/web/id/429/docserve.asp
« Reply #2 on: February 03, 2008, 05:37:13 AM »
Grant,
   You should be able to feed both inverters off your battery bank, but you cannot combine the inverter outputs. You can install 2 separate sub panels and feed each panel from a separate inverter.
   I recently installed a new Heart Interface 2000 watt inverter that had one 120 AC line in and two 120 AC  lines out. I called Heart Interface Tech Support and asked if I could combine the two 120 AC out lines. they said no, I had to feed two separate sub panels  (this inverter had 2 AC out circuit breakers on the front of it).
   Of course, you realize that if you run both inverters off your present battery bank, you will run your batteries down quicker?  Jack
grantgoold
« Reply #3 on: February 03, 2008, 07:27:39 AM »
I too looked at the install manual and couldn't find a stacking option so I thought I would come to the experts. I guess that I could use the second inverter/charger to charge the start and genset batteries and perhaps have as a backup unit should the first one fail.
Thanks for the input.
Grant
Grant Goold
1984 MCI 9
pvcces
« Reply #4 on: February 03, 2008, 08:56:34 PM »
Grant, Trace and Outback will stack, if you really need that feature. Not Heart.
If all you are trying to do is increase your 120 volt capacity, then an additional panel will be needed for the additional inverter. Why not look at a single inverter of 2500 to 3000 VA capacity?
The increased surge capability will handle most anything that you can manage to run on batteries and it is a much less complex setup.
If I were doing it, I would look at buying a higher powered inverter and bigger fuse and cables. That would leave you free to sell or store your existing inverter and wiring.
There is some peace of mind that owning an easily installed backup inverter can give you.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
« Reply #5 on: February 04, 2008, 05:24:58 AM »
Grant,
Jack,
How did you handle the neutral ground bonding in this situation?
