May 25, 2013, 10:27:31 PM *
Pages: 1 2 3 [4]   Go Down
Author Topic: Not funny.  (Read 3725 times)
compedgemarine
« Reply #45 on: February 26, 2008, 06:19:24 PM »
FWIW Chaz,
I am changing my thermostats which requires pulling the air inlet tube from the turbo to the blower and found a consideralble amount of oil laying in the tube. even though mine was making boost turns out it has a problem. luckily I had bought a reliabilt unit on ebay for cheap awhile back as a backup. if nothing else have you changed the air filter and pulled the air tube and spun the turbo to make sure it spins free? same with the fuel filters. lack of fuel or air will make them lay down.
steve
chazwood
« Reply #46 on: February 26, 2008, 06:36:22 PM »
FWIW Chaz,
steve
Now that's what I call puttin' the hay down where the goats can git it. I'll git on it.
Mine ain't just laying down .....I think it's asleep.
Thanks. Grin
« Last Edit: February 26, 2008, 06:39:39 PM by chazwood » Logged
1992 MCI 102c3
Cummins l10 / Allison auto
Thekempters.com
« Reply #47 on: February 26, 2008, 07:38:33 PM »
As noted, restriction in air or fuel could put it to sleep.  So if you don't find another simple solution that works, you may want to replace the fuel filter.  But if you do, be sure to do a search on the forum for tips on changing the filter and priming it.
Pages: 1 2 3 [4]   Go Up
