May 28, 2018, 03:07:53 AM *
Author Topic: weight of a 4104 shell guess correctly and win a prize  (Read 8159 times)
« Reply #15 on: June 07, 2006, 05:39:56 PM »
If you can, disconnect the cable in front and pull it all the way out. I't nice if you have a clean tub  or bucket of some kind to coil it up in.
Flush the tube out with WD40, kerosene, diesel ect. and blow it out with compressed air.
Clean the cable and lube with a light grease (I like the white lithium in a spray can) and insert it back into the tube.
Make sure when you hook everything up again that you can get full throttle at the governor.
Good luck,
4104bigred
« Reply #16 on: June 07, 2006, 06:00:53 PM »
great thanks for the info Len
chris
