May 27, 2018, 08:53:58 AM *
Author Topic: How to remove paint overspray from windshield?  (Read 8402 times)
« on: March 17, 2008, 07:04:32 PM »
A gentleman I hired to work on my bus used spray paint inside the bus.  He got overspray on the inside of the windshield.
Do I have to worry about wrecking the glass if I use a scraper to remove the paint?  I know windshields are not normal glass.  I don't want to wreck my new windshields that just cost me $2500 to install.
gmbusguy1
« Reply #1 on: March 17, 2008, 07:11:21 PM »
we do vinyl graphics and always use a new clean single edge razor blade to remove vinyl, the adhesive and paint on glass
Chris
Melbo
MC8 under construction
« Reply #2 on: March 17, 2008, 07:13:22 PM »
I have always used a NEW very sharp razor blade on glass including windshields and had no problems
I would be careful on the curved parts but the flat part should be no problem
HTH
Melbo
ea187
« Reply #3 on: March 17, 2008, 07:21:41 PM »
a razor blade should work or you can get stuff like acrysol it's made by kent and that is it's main job
4104GA
« Reply #4 on: March 17, 2008, 07:33:00 PM »
 Grin
I have used MEK and laquer thinner with good results as long as it does not drip on the painted surface.
Razor blades will not harm your windshields and are cheaper.
Enjoy your ride
Sojourner
« Reply #5 on: March 17, 2008, 07:34:37 PM »
Brake fluid will take paint off if let it be wet or soak for a day or so. Depend how old paint been on such as few months. Acetone will dissolve most paint as well.
Brake fluid will not hurt most plastic.
After paint removed....soap & water to wash off brake fluid. It water soluble.
If you use good razor blade....make sure the surface is washed clean to be free of dust & dirt before razor. To avoid scratches.
FWIW
Sojourn for Christ, Jerry
ceieio
MCI 7 DD 8V71, HT740
1973 MCI 7
« Reply #6 on: March 17, 2008, 10:25:50 PM »
Go to the hardware store or home center and buy a can of "Goof Off".  It is made to remove paints and adhesives (and more) from where they don't belong.  It should do just fine on your window.
Craig - MC7 Oregon
Craig MC7 - Oregon USA
Barn Owl
Roanoke, VA
PD4106-1063 "Wheezy Bus"
« Reply #7 on: March 17, 2008, 10:44:19 PM »
Non grit go-jo will work. Learned that one from a painter.
Kristinsgrandpa
« Reply #8 on: March 17, 2008, 11:32:22 PM »
    A razor blade will leave scratch marks. BTDT  Use anything liquid. I had a lot on the outside windows and used MEK.  acetone also works. Thinner also works if the paint isn't very old.
Mine is acrylic enamel with a hardener in it and thinner wouldn't touch it after a few weeks.
Ed
« Reply #9 on: March 18, 2008, 07:06:06 AM »
Easy Off oven cleaner works well too! Spray it on let sit for about 10 mins and wipe off!
Ray D
« Reply #10 on: March 18, 2008, 12:12:22 PM »
The razor blade should work, but you can also buy a clay bar at paint/detal stores which is used for removing overspray from paint, so should work on glass too.
Ray D
edroelle
1998 Royale Prevost
« Reply #11 on: March 18, 2008, 05:51:29 PM »
In college I worked for a painter and my first job was to clean windows.  I have used a razor blade BUT, I sprayed Windex to lubricate and ease removal of the paint.
Ed Roelle
Flint, MI
« Reply #12 on: March 19, 2008, 08:42:24 AM »
last little note: if there is any kind of tint film on the inside glass acetone may dissolve it (I know gas does as I have splattered tint on the inside of one of my van door window from filling up on a windy day with the  door open up wind of the pump) Moslty learning from mistakes here, the good news is I have made alot of mistakes.
Melbo
« Reply #13 on: March 19, 2008, 08:52:25 AM »
Isn't that the way we all learn???
The more mistakes we make the smarter we get
IF we don't make too big a mistake we will survive
Melbo
chazwood
« Reply #14 on: March 19, 2008, 01:56:55 PM »
I use 50 grit sandpaper.
No wait....that's for something else.
Never mind.
« Last Edit: March 19, 2008, 02:01:21 PM by chazwood » Logged
1983 Eagle Bus Model 10
6V92
Thekempters.com
