April 20, 2018, 11:04:46 PM *
Author Topic: Walmart oil  (Read 3896 times)
tekebird
« Reply #15 on: May 17, 2008, 07:18:55 PM »
I just asked for some documentation.......it may very well be true, But I'd like to see it inan officail publication rather than a board post from two guys I don;t know from Adam
tekebird
« Reply #16 on: May 17, 2008, 07:32:00 PM »
Doug, why do need a link the API rating of ash in cd or cf has always been 1% or less the ruling just gives you more options on oil the CJ4 or CI4 if you can find it 30 or 40w will work now just read the bottle  and fwiw  there will be no ash in 2010 some already are so find something else to worry about instead of the ash in oil for 2 strokes
now I am not automoticve engineer or chemist......but the C?-4 oils are specifically formulated for 4 stroke engines.    CI for instance is designed for 4 stroke engines.  In the past ten minutes I have located a load of online info that is way over my head technically re: the specific needs of two strokes as far as oil performance ( outside of ASH content.)
My engine........I'll be using the CF-2 oils that have confirmed Ash levels which can be easily checked on the manufacturers websites under product specs.
Timkar
« Reply #17 on: May 17, 2008, 09:03:48 PM »
Hope this link works....otherwise you'll have to cut and paste...
http://www.docs.citgo.com/msds_pi/729358.pdf
Cawston, British Columbia
tekebird
« Reply #18 on: May 17, 2008, 09:52:36 PM »
thx Timkar, what I was looking for was the EPA documentation on all being below 1%.
While I was reading tonight, seems Wallyworld switches oil suppliers like most people change underwear.  at least on thier car oils.....seems they buy through some repackaging company, who buys the low bid oil of the day
pvcces
« Reply #19 on: May 17, 2008, 10:36:29 PM »
For those who like using the oil from Canada, we do too. Mainly due to the cost and availability.
In the last few days, I was consolidating the results of the oil analyses we have had done. For the first three tests, we had some silica and iron, not real high, but worrisome. Most everything else seemed okay.
The fourth test was the best that we have had, iron and silica way down. It just so happens that we removed and replaced the bellows hose that runs from the air cleaners to the air horn. The old one was in bad condition and there was some evidence that some dirt had been getting past some of the bolt holes.
I also noticed that two levels dropped to practically nothing from fairly high levels. These were boron and magnesium. This was the oil that we had bought in Canada; all of the earlier tests were on Delo 100 40 weight.
Magnesium was listed as an additive/dispersant and boron was listed as a contaminant from antifreeze or possibly an additive. The test for antifreeze was negative.
I came to the conclusion that Delo probably has high levels of magnesium and boron, but the Canadian oil does not. I can't speak to how much effect these have, but they are probably there for a reason.
We probably will continue using the Canadian oil until we see some reason to change, partly because we run a toilet paper filter which gives us clean oil until the additives run low.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Iver
1979 MCI-9
« Reply #20 on: May 18, 2008, 01:28:48 AM »
The oil at Walmart (Canada) was 32.96 for 20 liters. (approx. 5gal. u.s.)
As tekebird said, I have also noticed Walmart uses different suppliers for their products.   I bought a gal. of anti-freeze a while ago and it was the typical green color.  I bought another gal. a month later (same name, same label exactly), and it was the red stuff.
By the way, is there a difference between the "green" and the "red" anti-freeze???
          Iver.
Abbotsford, British Columbia, Canada
"Life may not be the party we hoped for,
But while we are here we might as well dance".
tekebird
« Reply #21 on: May 18, 2008, 06:26:43 AM »
there are now three types of antifreeze.
when there was two there was a distiction between the green and red
seems now there is no distinction......I know the two original types are still available...and they do not mix well ( creat a nice snot consistancy stuff.......but the new will mix with both types.
BCM Webmaster
« Reply #22 on: May 18, 2008, 06:37:52 AM »
Yup, seems like antifreeze color is becoming a fashion or branding issue.  Now there is orange, purple, red and green that I've seen.  Before long, cars targeting young geeks will have clear coolant hoses with light ropes in them to show off the color of the antifreeze.   Grin
« Reply #23 on: May 18, 2008, 12:38:50 PM »
Many antifreezes are advertised as working with any colored anti freeze.
With your engine being the single most expensive item on the bus, why goof with cheap oils?  Detroit Diesel and Chevron worked together to make the correct oil for the 2 stroke engine-and that was Delo 100 sae40 weight.  That's what I use, and also what I used in my 8V-92TA, although with the turbo engines, it should be Delo 400 sae40 weight.  Good Luck, TomC
