June 21, 2018, 03:42:53 AM *
Author Topic: Ummmm.... unsavory question.  (Read 6704 times)
NEWELL in South Carolina
« Reply #15 on: May 30, 2008, 09:53:54 AM »
Kyle, you said you'd "roll your own". Any suggestions there??
jjrbus has it covered very well.
« Reply #16 on: May 30, 2008, 10:06:51 AM »
Check out West Marine
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/242955/377%20710%201506/0//Primary%20Search/mode%20matchallpartial/0/0?N=377%20710%201506&Ne=0&Ntt=&Ntx=mode%20matchallpartial&page=CategoryDisplayLevel1&isLTokenURL=true
« Reply #17 on: May 30, 2008, 10:17:38 AM »
I have found using the large hose a lot faster and more thorough than the macerator.  I bought a macerator that has a bayonet fitting that attaches to the dump valve.  It was less than $200., but that was about five years ago.  I have used it quite a bit, but still would default to the big hose.  Also, be careful about letting the macerator run without fluids.  It uses your sewage as a coolant for the pump and will burnout quickly if deprived.  The last time I used it, it ran for about 30 seconds empty before I got to it.  I think I may have damaged it, but will be using it tomorrow and will find out.  Of course, be careful about what you put in your septic tank.  I would not use any of the formaldehyde based tank treatments or any other that destroy bacteria.  The enzyme-type treatments, some of which are just shots of bacteria, would be okay.
Chaz
4108, 8V71 w/auto .
« Reply #18 on: May 30, 2008, 12:40:39 PM »
Well, I figured it was time to "S**t or get off the pot" so I made an executive decision from my "throne". I just ordered this:  http://www.pplmotorhomes.com/parts/rv-toilets-tanks/waste-water-pump-rv.htm?source=msn
I wasn't wanting to drop that much "cake" on this little issue, but 197.00 was doable. (on sale today) The initial 500.00 was not even a consideration.
So now hopefully I will be a "Happy Camper"  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy LOLOL
By the way, after searching around on the net, that IS a good price if any of you are contemplating such a thing.
  Livin Large,
     Chaz
« Reply #19 on: May 30, 2008, 01:26:51 PM »
Well, I'm gonna stick with my $30 stinky slinky for now.  Grin
A macerator pump can give new meaning to "shooting the s#!t"   Shocked  Shocked  Shocked
Chaz
4108, 8V71 w/auto .
« Reply #20 on: May 30, 2008, 02:36:39 PM »
HA!! Good one!  Cheesy
Altho I've been known to "shoot" a little, I PRAY this is one kind I don't!!!   Shocked   Tongue   Grin
But if all goes well, I do believe this is a good way to go. Especially to be able to dump at home and not need a plumber to come out and set up something to dump in.
  Eat your roughage and keep'em floatin, Kyle! Grin
Chaz
RTS/Daytona
« Reply #21 on: May 30, 2008, 05:34:30 PM »
check out EBay - under macerator
« Reply #22 on: May 30, 2008, 06:24:41 PM »
That's similar to what I have, but I do not have the remote switch although you really can't get to remote anyway. It appears to be a good price for it in kit form.
Chaz
4108, 8V71 w/auto .
« Reply #23 on: May 30, 2008, 08:29:22 PM »
Lin,
  That's what i thought. I did check ebay, I looked at all of them but I figured what little I would save in money "rollin my own", I'd spend in time and aggrevation. And the deciding factor was that I couldn't set it up permanently like jjrbus did as I don't have the room. So the kit made the best sense. At least I'll find out after next weekend! Smiley  Wish me luck!  Wink
 Chaz
« Reply #24 on: May 30, 2008, 08:35:13 PM »
It's good to have.  Just don't get your hoses mixed up.
« Reply #25 on: May 31, 2008, 01:18:37 PM »
I have the same setup as Lin and really like it.
I use the 3" at campgrounds but use the portable macerator pump at home where I can't get close to my sewer cleanout. I use a plain 5/8" garden hose with no problem.
One word of wisdom about the pump, it makes a lot of pressure so be sure the discharge end of the small hose is well held down - don't ask me how I know this!!
Two 3" hoses is a very good idea. You will very often be just not quite close enough and sometimes you will even have to dump on the opposite side. That really gets to be a mess.
I would add to that to have the bayonet type quick-connectors at all connections. You don't really want to be fooling with screw on or clamp types when things get messy.
Camping World also has a 3"clear plastic  elbow with a garden hose connection for cleaning out the 3" hose or portable macerator pump. It helps to be able to see when things are getting cleaner.
« Reply #26 on: May 31, 2008, 04:54:57 PM »
Just another note.  I have about a foot of clear plastic hose on the discharge side of the macerator and connect the hose to that.  That way you can see when the flow has stopped.
« Reply #27 on: June 02, 2008, 10:52:49 PM »
WOW! Shocked Shocked Shocked  Guys,,,,really Embarrassed   I full timed for years and I only had a stock hose from CW.  I NEVER used any additives and never had any smell except when a PVC drain split.  I waited till the black was full to the top and drained in a dumpsite or just opened the valve if in a park and then drained the grey.  All I did to the hose before storing it was, at most, run a little fresh through it, hold the end up high to let it drain and stow it.  I never wore plastic gloves because I never needed them.  If I got a few drops on my hands, well I washed after doing this chore anyway and I didn't visit during a dump adventure and there was no need for shaking hands to be a concern. Wink
A macerator seems a good idea but I can imagine going years before actually using it....still. Smiley  CHEWING up your poopy and circulating it back into the black tank before dumping through a 3 inch hose?  Now that was inspired by Stephan King. Tongue Grin Grin Sorry, couldn't resist.
The more spendy drain pipe lasts a lot longer than the cheepy blue item.  The blues never lasted more than a year.  Bad part was that you only discovered you had holes when you need to use the darn thing so after 5 years I switched to the spendy grey hose made of thicker rubber.
Good luck here now to all.  And KIS is the motto.  This ain't deep and better never be Wink Cheesy
