February 25, 2018, 01:56:23 PM *
Author Topic: Low oil pressure on 4104 671  (Read 1527 times)
JT4104
« on: June 11, 2006, 07:00:38 AM »
My 671 as of late has lost oil pressure after warming up to where it is only showing 5-6 lbs pressure on idle.
When I start it, it shows 40 psi on idle, 60-70 psi on high rpm.
When harmed up, even on high rpm's it won't go above 30 psi and my dash meter shows no pressure (although the oil guage on the engine shows 5-6 psi).
Using 40 weight shell rotella, changed the oil and filter but same problem.
Time for a new oil pump?  Any suggestions would be appreciated.
JT4104
plyonsMC9
Big Wheels Turnin'
« Reply #1 on: June 13, 2006, 11:16:57 AM »
Hey there JT - any luck with your 671?  What's going on with this?
Folks - any help / suggestions for JT?   Smiley  Grin
Kind Regards, Phil
PS - Welcome to the board JT!!
Northern Arizona / 1983 - MC9
« Reply #2 on: June 13, 2006, 10:14:33 PM »
Phil,
This post was duplicated later and he got a bunch of responses.
