May 23, 2018, 04:15:40 AM *
Author Topic: Using blocks to level  (Read 1079 times)
« on: June 23, 2008, 06:04:26 AM »
I had asked this question within a previous post on leveling, but as that one dealt with leveling systems, it was out of place.  For the present, I am using blocks to level.  I have always felt more comfortable putting blocks under both of the dual wheels but have seen others do it by just blocking the outer wheel.  Which is the best way to do it?
Eagle
1985 Eagle
« Reply #1 on: June 23, 2008, 06:47:49 AM »
Blocks under both tires.  If placed just under one tire it will place a lot more stress on the one tire than it was designed for.
« Reply #2 on: June 23, 2008, 01:39:33 PM »
NYAAAA.  Wrong answer.    Grin Grin
Block whatever is convenient to block.  The static load sitting on a block is a fraction of the dynamic load that tire faces going down the road.  Worrying about blocking is a waste of good worrying time IMHO.
