June 20, 2013, 05:00:38 AM *
Author Topic: Window screens revisited (for those that don't mind being tacky)  (Read 848 times)
« on: June 25, 2008, 04:41:45 PM »
In a recent post, I got some good advice on ways to screen my original bus windows.  The most efficient way seemed to be to use Velcro to attach the screen material to the window frame.  I was about to do this and bought a large roll of Velcro, gathered up some tools, and was going to start.  I happened to notice that my wife had this pop up, mesh laundry hamper.  It has spring wire around the sides, so it can be folded or allow to open fully like those dash sun protectors for cars.  It seemed that such a spring wire set up would be great for removable screens.  Now, you Peninsular Window guys, should not read any further.  This is only for those that can accept a less-than-elegant solution to unscreened windows.  I wondered whether I could construct such a screen, but then also wondered whether I could find those pop up, mesh laundry hampers in my window size.  Well I tried the latter (Doesn't this seem like the type of idea you'd find on a schoolie site?).  I checked out ebay and ordered some that looked like they might fit.  This is pretty much a blind task because the measurements they give are not so precise.  My "new screens" arrived today.  They do not fit perfectly, but they do work if I use two per window.  The holes in the mesh are larger than screening material, but they should filter reasonable well since the mesh is in two layers from the hamper being collapsed.  I am not sure if they would be useful in gnat country, but should be okay for flies, mosquitoes, etc.  We are going on a trip tomorrow, so we'll know soon enough.  Although this may not be exactly graceful, I will compromise for a good night's sleep.
I just wanted to share this in case there is anyone else on this board who, like myself, has a terrible lack of standards.  The worst part of it is that since I wanted to get them in a hurry because of tomorrow's trip, I could not be too fussy about colors.  I ended up with blue, red, and green.  If the experiment works out, I will give this as birthday presents for my kids (they don't know what they're missing), and search out some in a dignified black.
« Last Edit: June 25, 2008, 06:30:56 PM by Lin » Logged
Nusa
« Reply #1 on: June 26, 2008, 04:03:25 AM »
Those pop-open hampers are sold by my local Walgreen's, 2 for $5. I've got a couple black ones in my closet...each holds just the right amount for one load of wash (for my washer, anyway).
Here, I found it in their online store too. Size is 21" x 13" x 13":
http://www.walgreens.com/store/product.jsp?CATID=303297&navAction=jump&navCount=0&skuid=sku1307586&id=prod1307596#
sommersed
« Reply #2 on: June 26, 2008, 08:03:00 AM »
I solved my screen problem by leaving  my 80% sunscreen up permanently on both front side windows, which are still the original bus windows on my MCI5A.  An added plus is that in hot weather I can slip some foil covered bubble wrap under the sunscreen so the window is covered from the outside, makes a BIG diff is the heat transfer department.
Ed
« Reply #3 on: June 26, 2008, 08:08:40 AM »
That's them.  I just wanted a different size for the window frame.  If the concept works, it seems that one could cut screening material to size and make a pop up window screen.  One would just need to find the right wire length.
