January 23, 2018, 03:43:38 PM *
Author Topic: Dash Gen. light on with house Gen. running  (Read 1776 times)
JimC
« on: June 12, 2006, 03:40:08 PM »
Hi all,
On my 4106 the dash generator light lights up when house generator is started. It just started to do this, and it is bugging me that the only way to drive with air conditioning working is with that big reg light staring me in the face.
I have an automatic transfer switch, and I have a feeling that somthing has malfunctioned within it, but the auto switch seems to be working like always. I tried running the 8/71 with the bus plugged into 120V and it does not light up under those conditions.
I am electrically challenged, so if anyone has an idea, please keep in in very simple layman terms.
Thanks in advance
Jim Callaghan 4106
Oconomowoc, Wisconsin
between Milwaukee & Madison
« Reply #1 on: June 12, 2006, 03:56:03 PM »
Without seeing a wiring schematic I am guessing, but frequently poor ground connectrions can cause gremlins like this. I would check all your ground connections on the generator and the bus charging circuit as well as the dash light. Hope this helps, Jack
« Reply #2 on: June 12, 2006, 05:13:41 PM »
Also verify that the generator isn't driving a battery charger that's trying to charge the cranking batteries. The "Not Gen" light will light if you have battery chargers charging the batteries when the bus alternator should be doing the charging.
What is your battery volts when the genset is running?
If you have not done so, your generator should have its own cranking battery. The day will come when you'll need the genset and won't be able to start it.
I have to be sure that my inverter is turned off when the genset is on for AC or whatever and the engine is running.
However, did prove once again (I knew this, but it comes up frequently) that an LCD TV will run off of modified signwave inverter without issues. I've got a cheapo (relatively) Trace DR2424 and it has operated any and everything that I've plugged into it.
JR
