April 20, 2018, 01:36:46 PM *
Author Topic: Seal lost on thermopane window  (Read 8007 times)
jjrbus
MCI5C/N Ft Myers FL
« Reply #15 on: July 19, 2008, 07:58:35 AM »
 On reasearching this I found a glasss shop, it is amazing how few shops there are.  The man who owns it told me that once the seal is broken the chemical used as a disectant will etch the inside of the glass and rendered it unusable. He stated, belive me I have tried. His suggestion was to use a laminated auto glass for replacemnt at about $150, or go to an RV dealer to locate a replacement insulated glass.
 He indicated that he does not have access to thin insulated glass and that an RV dealer would be the best option.  I dont know about you but an RV dealer would be a last resort. So back to the web to find a manufacturer.   Jim
Bob Belter
« Reply #16 on: July 19, 2008, 10:12:31 AM »
Ahoy, BusFolk,
1:      I'd suggest you try flooding with Argon gas as discussed above.  (I have made ~~40 thermopane windows for my home).
2:      There is not a vacuum inside.  The glass is nowhere strong and stiff enough to sustain the loads.
3:      Silicon sealant is NOT effective for thermopane.  It transpires water vapor.  Butyl rubber is what to use.  Hot melt butyl is the way to go.  I don't know how effective ordinary caulking gun butyl would be  --  Give it a try -- Might work ,and it dissolves with mineral spirits if it does not work.
Enjoy  /s  Bob
Sojourner
« Reply #17 on: July 19, 2008, 12:15:23 PM »
Amen of what Bob Belter said...NO SILICON sealant. Butyl only. They make a butyl compound with desiccant that being use every day.
The today method is to use hot-melt desiccant compound along with newer type sealing compound & spacer.
Open the link and cursor over the color dots:
http://http://www.adcoglobal.com/adcoproducts/was.asp
Here a link to "No window is ever hermetically sealed" I am learning that it true from seeing thermopane getting cloudy in time.
http://www.sunshinewindowcleaning.com/windowdefog.htm
FWIW
Sojourn for Christ, Jerry
