February 18, 2018, 04:14:19 PM *
Author Topic: Relay? valve leaking  (Read 1733 times)
KC Eagle
83 Eagle in process
« on: June 12, 2006, 06:57:56 PM »
Greetings all! I am doing my conversion entirely from advice gleaned from lurking on this board (well, not quite, but close). I aired up the system of my model 10 Eagle in preperation for a move and I have a steady leak from what I believe is the exhaust port on the right rear relay valve (sits low near center of coach midway between the drive and bogie). I rapped lightly a few times on it in an attempt to dislodge a possibly stuck valve but it had no effect. I noticed this port appears to have 4 screws holding it in and am thinking about removing them to see if there is anything I can clean out?? I also noticed the cooler ( the copper "S" bent piping) has been disconnected and bypassed so that the compressor output goes directly to the Bendix air dryer - should I attempt to get this reconnected? I assume there must have been some type of leak or damage to account for the disconnect. Suggestions?
FloridaCliff
"The Mighty GMC"
« Reply #1 on: June 12, 2006, 07:07:55 PM »
KC,
Chock the wheels, release the parking brake and see if you still hear the leak.
Usually the sound of escaping air  in the relay is from another source like a diaphram.
If the leak goes away, block the bus, set the parking brake,  clamp off each of the air lines into the relay (vise grips) one at a time until it goes away.
If this doesn't identify where its coming from let us know.
Cliff
Mark Twain
