June 21, 2018, 10:35:08 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Cummins ISM Oil pan help  (Read 8764 times)
Bob Belter
« Reply #30 on: August 15, 2008, 04:40:00 PM »
Ahoy, Brian,
Sorry, I missed that your ISM oil pan is aluminum.  The welding teqhniques above should give you very good results.
OR~~~~~~~~~~
I'll bet that the bolt pattern is the same as the M-11, so you could do what I did on a steel pan.
I just accepted the lesser oil quantity.  I change oil a bit more often.  Never any temp problems.
Enjoy  /s/  bob
Brian Diehl
« Reply #31 on: August 15, 2008, 07:04:06 PM »
Thanks Bob,
How much less oil capacity do you have?  The ISM is designed to run with 9 gallons full and 7 gallons low on the normal truck pan.
-Brian
Bob Belter
« Reply #32 on: August 15, 2008, 08:30:19 PM »
Ahoy, Brian,
I'll check my oil pan depth in the AM and let you know.
The original oil pickup tube is about 1.0" dia with a simply scarfed end at maybe 45deg.  Quite crude, and certainly prone to cavitation even with oil level well above the top of the scarf .  Since I reduced the distance from the top of the oil level to the tube inlet, I felt that a cavitation plate would be quite prudent, along with  a 'rock' screen --  (Which my M-11 did not have).
Most of this M-11 is really good, but it appears that no one is perfect.
For instance, there is a formed ~~5/16" main fuel feed to the head from the pump.  Uses a 1/8" mpt brass fitting. Broke at ~~30,000 miles.  Really quite 'light weight' when you take a good look at it. Turns out to be a well known fault to Cummins mechanics.  I replaced mine with a steel fitting and SS braided hose.
I know more than I had planned to learn about oil cavitation in my dry-sump 'E' class racing boat, and also my Porsche Speedster race car.
Enjoy  /s/  Bob
Bob Belter
« Reply #33 on: August 16, 2008, 11:21:18 AM »
Ahoy, Brian,
My oil pan depth from the flange to bottom is 8.0", from the crank case is ~~8.25".
As I noted, I have no oil temp problems, no pressure problems.  The amount of oil carried only effects the rate of oil temp change.  So long as you have quite enough oil to insure no cavitation, you are OK, and your oil cooler system (which is integral to my M-11) controls the equlibrium temperature .
The big 'round' engines which I used to fly had NO oil in them.  Dry sump, with  an oil tank, and of course a cooler system.  Oil temp was the same regardless of quantity.
New note:
Pebble Beach / Carmel / Laguna Seca Auto Week here!!!!  You find yourself in a traffic jam, and realize that your insurance coverage would NOT even put a fender on half of the cars around you.  Yah, and some of them drive as though the have just stolen them!!!
Enjoy  /s/  Bob
« Reply #34 on: August 16, 2008, 03:31:53 PM »
Hey Bob,
When I was stationed at Fort Ord, 69-71, we used to love those days. We would take a jeep and watch the races from on post.
A long, long time ago.
« Reply #35 on: August 16, 2008, 03:44:27 PM »
Paul,
You mean you had to retread Basic that many times? LOL   Grin Grin Grin
Hey Bob,
« Reply #36 on: August 16, 2008, 03:47:33 PM »
Dallas,
Basic was at Fort Lewis....HA..
NJT 5573
« Reply #37 on: August 16, 2008, 04:06:37 PM »
You could get your total gallons up and do your engine a big favor by installing a remote Luberfiner 750.
Pages: 1 2 [3]  All   Go Up
