February 17, 2018, 03:52:11 PM *
Author Topic: could this really be?  (Read 4048 times)
Blacksheep
« Reply #15 on: September 14, 2008, 04:39:51 PM »
Aww gee fella's, I made a mistake!!!
When I posted I stated 60 gals., but as I was reading your postings to Susan, she corrected me. She's the one that keeps the books/records. She said it was actually 59 gals..
Now doing the math and reading what you all had to say, I feel like it went the wrong way. I was actually hoping to be closer to what you all said it should be. All I know is the roads are really flat and boh tiomes there was little to no wind but I did forget to mention I was pulling a very small trailer with a golf cart!
I can't explain it so as long as the bus is running as good as it is, I really could care less if its 5mpg or 10mpg. If I couldn't afford it and had to worry about it I would have never got involved in this hobby! 1, 2, or 3 mpg is not going to make me or break me!
jjrbus
MCI5C/N Ft Myers FL
« Reply #16 on: September 14, 2008, 05:25:38 PM »
 It really could be!!!!  I was getting the  same milage Ace. What I found was the return fuel line to the tank was partially blocked. It would only leak under high pressure or at highway speeds. There was a loose couplng that fuel could be forced through. Darnest thing it sprayed it on the highway at highway speeds and did not leak at low speed so I never saw the leak!!
 Better look for something like that, I dont know how you can afford to drive a bus with that kind of milage!!  HTH Jim
white-eagle
« Reply #17 on: September 14, 2008, 06:39:16 PM »
did i misread something or was jjr just pulling bs's leg.  i'd be ecstatic with 9.35.  freeway home from valdosta to cinci, used 96 gal and got 7.1.  i thought that was great for 8v92 pulling an express van full of stuff.
Ace, you've had way too much posting lately.  is Susan still with you?  you're spending a lot of time on pushing the wrong buttons on this bullitin board.  Cheesy Cheesy
« Last Edit: September 14, 2008, 06:41:10 PM by manasst » Logged
Tom
Sojourner
Jesus Love You!
« Reply #18 on: September 14, 2008, 06:48:25 PM »
Example if in the ground tank of diesel fuel is 40F cooler than above ground tank (100F)
. The thermal expansion coefficient of Diesel is 0.00046/* F. Assuming constant atmospheric conditions.
So .00046 X 40F = .0184 gal X 200 gallon = 3.68 gallons gains using cooler fuel.
So which will give more for your money?  Cold fuel. In other words, for every 54.35 gallon of colder (40F) fuel, you gain one gallon
Or, in Ace case. If you pump in 54.4 gal @100F fuel in tank and after shut down to soak up the cool over night temperature of 60F, you lose 1 gallon in the morning.
It about expansion and contraction in large quantity.
The bottom-linenever buy very warm or hot fuel before the next morning. But fill up in the morning or go some where they have cool fuel.
For every gallon you gain, multiply that times mpg = XX number of more mile for the money.
Some pump has build in temperature compensator, so it wont matter what fuel temperature for the dollar.
FWIW
Sojourn for Christ, Gerald
« Reply #19 on: September 14, 2008, 07:16:04 PM »
My understanding is that almost no gas pump in the USA has temperature compensation.  I also understand temperature compensation is somewhat common in Canada due to the colder weather.
It has been explained that temperature compensation in the USA would make very little difference in fuel quantity delivered.  The tanks are underground and the ground stays at a relatively constant temperature year round.  This is how geothermal heating/cooling works.
Some stations have been accused of heating fuel to cheat customers, but others have explained that the amount of energy required would negate any extra revenue.
« Reply #20 on: September 15, 2008, 05:49:57 AM »
I don't know if it makes much difference, but I have seen several tankers sitting in the sun at Flying J dumping into the underground tanks as we were filling our coach, along with several truckers.  Jack
Sojourner
Jesus Love You!
« Reply #21 on: September 15, 2008, 08:15:53 AM »
Thank Jack...You said it better and added thought to our bus nuts to be aware that you can save few dollars.
Keep IR gun near by in a handy place...you be amazes what we miss for the pass knowledge you have had.
Have fun with IR gun!
FWIW
BTW...IR gun check tanker temp...next time you are there. If they ask...tell them "I am learning about temperature"
« Reply #22 on: September 15, 2008, 09:10:51 AM »
More than likely just a one time deal I have had those spikes in mileage over the years but I would not plan a trip with a 8V92  based on 9 miles per gal when you get a 2 mile per gallon spike it will be different the next tank is for me anyway brings me back down to reality .        good luck
« Last Edit: September 15, 2008, 09:19:10 AM by luvrbus » Logged
edroelle
1998 Royale Prevost
« Reply #23 on: September 15, 2008, 10:18:10 AM »
You should track your mileage as an ongoing process.
I would expect your next fill-up will be disappointing relative to this fill.
Ed Roelle
Flint, MI
Blacksheep
« Reply #24 on: September 15, 2008, 10:33:02 AM »
I guess I could hook up my prolink and see what it says! Would you think that it is accurate?
« Reply #25 on: September 15, 2008, 06:08:39 PM »
Canada has had laws requiring temperature compensation for the fuel pumps for many years.
The American consumer is being ripped off, cents at a time, or in a busnut's case, dollars at a time.
I continue to be surprised that this theft goes uncontested.
NEWELL in South Carolina
« Reply #26 on: September 15, 2008, 07:14:54 PM »
It's a conspiracy!
& since they are shafting us at each fillup, heck, we're all getting better mileage than we thought!
 Grin  Grin  Grin
