May 21, 2013, 07:09:02 PM *
Author Topic: Onan 6.5 points to electronic ignition conversion.  (Read 14070 times)
NCbob
"Foolish Pleasure" 35' MC5A
« Reply #15 on: October 06, 2008, 05:46:43 AM »
JohnEd, on those rare days when I really felt like setting the timing on one of those rascals (most of the time they were in a hole where you couldn't see you hand in front of your face) they were mostly on the bench. In order to see the timing marks there was a lot of tin to remove. Generally speaking if you make sure the point plunger is DOWN and install and set the points (.018) and button it up. I rarely saw timing as a problem on these small engines.
If you can find one of the old vibrating reed freq. meters you can set the speed by simply resting the meter somewhere on the genest. It will sense the vibrations and give you an accurate 61 Hz to set the speed.
Best of luck,
NCbob
Sojourner
Jesus Love You!
« Reply #16 on: October 06, 2008, 04:03:16 PM »
Best of luck,
NCbob
Or plug in a 110 v ac dial clock or analog into generator that side by side to your cell phone’s seconds or better yet another analog clock plug into land line power source. If generator is running too fast…it will cause the “generator clock” to run faster than land line power clock and will result a higher voltage.
Adjust your generator engine governor to slower or faster RPM until both analog clocks second hand is running the same speed or time matches. You should be in the 120 volt range after the adjustment.
All ac analog clock speed is depending by the cycle per second. Which is USA standard of 60 cycle.
Sojourn for Christ, Gerald
« Reply #17 on: October 07, 2008, 08:13:46 AM »
That's one of the nice things about my Trace inverter-it has a hertz readout to make generator speed adjustment a snap.  Good Luck, TomC
« Reply #18 on: October 07, 2008, 07:00:05 PM »
TomC,
The reason I figured this thing couldn't fire the two cyl separately is that it had only one lobe on the cam so the points opened at the same place ever time.
It may be that one spark plug fired during an exhaust stroke and the other during compression, I was never really interested enough to check out piston position.
My guess is that your JBD also has the pistons moving together if my guess is correct about the gas setup.
A four stroke fires every other revolution, only a two stroke fires every revolution. Two strokes, one down, one up = one revolution.
NCBob,
I wondered about that distributor part, I couldn't remember any dist on mine?
compedgemarine
« Reply #19 on: October 07, 2008, 07:13:48 PM »
If it does fire both cylinders at the same time it is called a wasted spark ignition. we used that on some of our race motors. seems odd but works fine.
steve
Barn Owl
Roanoke, VA
PD4106-1063 "Wheezy Bus"
« Reply #20 on: October 07, 2008, 10:25:18 PM »
I just got back from my last campout for the year and I am now soaking all of this in. Keep posting if you can.
