April 26, 2018, 02:49:50 AM *
Author Topic: Pit price  (Read 4557 times)
« on: October 16, 2008, 03:53:51 PM »
Got a price on a 40 ft x 14 ft slab with a 4fth x4ftw x 20 ft long  pit x 6" thick  for $5,550.00 do you think this is sounds about right Huh?
« Reply #1 on: October 16, 2008, 04:00:40 PM »
sounds about right $3.00 sf for flat work $10.00 sf for walls 2 years ago that would have been on the cheap side     good luck
« Reply #2 on: October 16, 2008, 04:25:48 PM »
Concrete is running about 130 a cu. yd. Figure up how much concrete is needed and then you can tell roughly how much labor is. Your price sounds about right for our area. Flat work is certainly cheaper than pouring the walls. Does this price include digging the pit or not?
God bless,
Tom Y
« Reply #3 on: October 16, 2008, 04:40:21 PM »
John, Would a 5 foot high pit work better?  Tom Y
Tom Yaegle
jjrbus
MCI5C/N Ft Myers FL
« Reply #4 on: October 16, 2008, 05:01:56 PM »
depends on how tall he is    Grin
« Reply #5 on: October 16, 2008, 05:02:31 PM »
When I built my shop (which I no longer have) I went 5 feet deep and then used a small step stool in the pit.  Made it much easier to work in.
I would also suggest a slight slope in the bottom and a sump pump at one end.  Even if it never floods, it makes it much easier to hose down the floor for clean up.  I also piped in electric and compressed air, a great convenience.
HB of CJ
« Reply #6 on: October 16, 2008, 05:03:20 PM »
Have no idea about your $bid$ price.  Been out of the trades way too long.  Does that include entry steps, a per code drain(s), brackets or slots for various level stands and wiring/switches for required lighting?  Also, have you considered going a little deeper for the pit?  Smiley Smiley Smiley
« Reply #7 on: October 16, 2008, 06:03:19 PM »
The price does include the digging. I will have to put The light,air and sump pump in. I was going to use a cut of ladder, but I bet I could get them to put steps in. The reason for the 4 ft depth is that the water table by the coast is low.
Tom Y
« Reply #8 on: October 16, 2008, 06:57:16 PM »
John, Don't you love the people who don't answer the questions? I hope, as heres another. You may want to measure between your duals, is 4 feet to wide?  Goodluck  Tom Y
Tom Yaegle
PP
Will & Wife
« Reply #9 on: October 16, 2008, 07:05:53 PM »
John, Surely you mean the water table on the coast is 'shallow'?
makemineatwostroke
« Reply #10 on: October 16, 2008, 07:12:51 PM »
  On the Texas coast I think he means the water table is high
have a great evening
« Last Edit: October 16, 2008, 07:27:14 PM by makemineatwostroke » Logged
« Reply #11 on: October 16, 2008, 07:26:12 PM »
Hi John,
Having a pit for 20 years, I would suggest that you go 5ft deep. You may get a sore back with all the bending over....
Another place you can save $$ is the legenth. You can cut it back to 15ft and just move the bus over the work area or just turn the
bus around to work on the front end.
My dad's pit measures 15'L x 5'H x 4'W and worked just fine.
Good Luck
« Reply #12 on: October 16, 2008, 07:42:10 PM »
If there is a problem with water at 5 ft he is doing the smart thing by going 4 ft it cost a several bucks to waterproof concrete and without a drain around the wall it is still a problem      good luck
Sojourner
Jesus Love You!
« Reply #13 on: October 16, 2008, 10:49:39 PM »
About problem with high water table....you can raise the concrete's earth base up with good packing fill dirt about a foot to achieve the needed depth.
FWIW
Sojourn for Christ, Gerald
HB of CJ
« Reply #14 on: October 16, 2008, 11:04:03 PM »
johns...I'm sorry if it appeared I was nitpicking.  Didn't intend too. I also had a high water table to deal with in SW Oregon years ago.  Others have already suggested "raising the pad".
Shortening the length of the pit never occured to me.  Brilliant.  About the only thing I can think of and forgot before is maybe the need for plumbed airline pipes and stuff.
This sounds silly, but...how about wiring in a landline telephone jack at each end?  Dunno if your have cell service or not.  Lots and lots of extras.  Used to drive us crazy.  Smiley Smiley Smiley
