May 25, 2018, 03:47:40 PM *
Author Topic: House batteries  (Read 4295 times)
centrix29
Prevost Proud
« on: April 07, 2006, 10:46:57 PM »
Hi all,
I'd like to connect 8 Lifelong 8Ds together for my house battery bank. What size cable do I have to use for that? What size charger should I use if I am using a seperate 3000w. inverter?
Thanks a lot!
Pat
« Last Edit: April 08, 2006, 01:33:56 AM by centrix29 » Logged
« Reply #1 on: April 08, 2006, 07:42:28 AM »
Two questions, is the battery voltage to be 12 or 24 volts and does your inverter not have a built in battery charger?
 Most of them have that feature included for the DC voltage that you want.
centrix29
Prevost Proud
« Reply #2 on: April 08, 2006, 10:46:28 AM »
My inverter is 12v. I have yet to buy the charger.
Thanks!
« Reply #3 on: April 09, 2006, 02:07:19 AM »
centrix29 ,
What is your mo# & ser#  and also make of your inverter??
We will be able to help you better with more info!
Nick Badame
alkco1-rts
« Reply #4 on: April 09, 2006, 09:41:05 AM »
I have been involved in doing some solar systems and for batterys they recommend using batterys with lower voltage in series to come up to your useage volts. For example 3-4volt= 12 or 6-2volt=12 or double that if your system is 24V. Hope this makes sense.
Leroy
