April 22, 2018, 09:18:22 AM *
Author Topic: two air valves on throttle??????  (Read 775 times)
mccarlk
1967 mci 5 8v71 auto
« on: October 19, 2008, 04:46:27 PM »
hi on the housing there is the throttle lever and then there is 2 air valve , is one fast idle and the other is fuel shut off?, if so what is the measurement between the end of the valve, and the levers, with no air applied, thanks
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
