Tires and Bus Weight - Why your GVWR is Important
Started by Gary Hatt - Publisher BCM, February 23, 2025, 08:04:34 AM
Previous topic - Next topic
The article discusses the challenges of managing a bus conversion's weight, mainly focusing on the importance of adhering to weight regulations to ensure safety and avoid legal issues. It shares an anecdote about the author's experience with weigh stations in Missouri and the potential problems caused by exceeding weight limits, such as tire failures and overworked components.
It explains that passenger buses (for now) are subject to weight restrictions based on their Gross Vehicle Weight Rating (GVWR) and axle limits. It highlights the importance of properly maintaining tires and monitoring weight distribution. It also touches on the impact of overloading buses and how regulators will likely focus on weight and tire inspections.
BCM Members can read the full Article by clicking the link below. You can also choose the 'Click HERE to Read this Article to me' button to have it read to you, making it easier to absorb the information while multitasking.
https://www.busconversions.com/articles/new-articles/
You can read several older articles today if you are not a current BCM member. Click on this link to access over 200 articles about converting any wheeled vehicle into a home on wheels.
https://www.busconversions.com/online-articles/
Become a member for only $12 annually and gain immediate access to all New Articles and Buses for Sale six months before non-members. You will also have access to other valuable information and discounts on all RV components and be able to read over 2,500 articles on Bus Conversions that apply to any RV conversion you are interested in converting.
https://www.busconversions.com/membership/
1999 Prevost H3-45
Gary@BusConversionMagazine.com
Jim Blackwood
Does any of that ever become an issue with the 102DL-3? I would kinda doubt it given the full capacity passenger weight.
I saw it on the Internet. It MUST be true...
Quote from: Jim Blackwood on February 23, 2025, 10:09:28 AM
If it is a conversion, I wouldn't think so, but if you added extra range fuel tanks in one of the bays and 250 gallon fresh and a 250 gallon grey/black tank as I had in my MC-7 Combo, and a washing machine, large refrigerator, built in ice maker and several other appliances, and if you carry a spare tire and lots of tools and spare parts in the bay as I do in my bus, then yo may want to have it weighed.  My personal opinion only. Others on this site may be able to provide more information than I can.
1999 Prevost H3-45
plyonsMC9
There have been several discussions on the forum re: proper tire inflation based on the weights carried at each axle.  I've seen situations where tires inflated to full amount listed on the sidewalls created a very harsh ride in our DL3.  I dropped PSI down just a small amount ( < 5 lbs) and it made a huge difference in ride quality.  I've not yet taken the last step, which will be to contact the tire manufacturer requesting the chart detailing weight and recommended PSI.  I've never seen such an item but it has been mentioned on this forum a few times.  I'm planning to do so in the near future, especially now that I've put my name on this post.  :-|
I have had the DL3 weighed front & back.
Hope this helps, Phil
Northern Arizona / 1983 - MC9, 1995 MCI DL3-45
The 45 ft buses of today are not your father's Oldsmobile,it takes very little to overload the front axle, that is why you see the 365/ 22.5 tires on the front axles now. Conversions are heavy Newell and Prevost are 55,000 GVW lbs now, my Country Coach was 52,000 lbs GVW. They are not using the old reliable straight axle any longer to carry the weight on conversion, they use  the independent suspension and it offsets the 130# psi in the tires ,you can check the Prevost VIP shells for weight and the conversion VIP shell  is rated higher than the passengers' model. Good thing about a DYI conversion you don't have to use all the Granite counter tops, stone floors and 4 slide outs folks want today
