Adding Fast Idle? (4104)
Started by Nova Eona, October 18, 2019, 08:13:50 PM
Previous topic - Next topic
chessie4905
If you are short of baggage compartment space, you could use one of those compact dual tank unit, and install it under an ac shroud.
GMC h8h 649#028 (4905)
Pennsylvania-central
Sebulba
That is great.  Let me ask you.  Can the scuba tank be replenished with any old air compressor or the bus air?  Or do have to go have it refilled somewhere?
Seb
Quote from: dtcerrato on October 22, 2019, 04:44:39 PM
Or better yet a SCUBA tank. That's right, a SCUBA tank. Holds over 93 cu ft of air @ over 3500 psi. When dropped down to 100 psi by the first stage of any standard SCUBA regulator there's enough air to run the whole bus down hilling using brakes for a long long time. We're gonna put one in besides the aux. Electric compressor cause we love redundancy... No need to start engine nor aux. compressor with the genny, just a whole lotta air in one small compact cylinder...  8)
Back to the U.S. after 8 years in Europe.
Bought a 1997 MCI 102D3 with Allison B500 on November 17, 2021 in Syracuse, NY.  Commenced living it that day and  drove it to Florida and New Mexico.  Converting as we go. All most done now.
chessie4905
93 cu ft of air? I doubt it would last long enough if you could get the volume you would need for backup. Plus, the cost of refill. Might as well go with a welding oxygen tank. At least if you couldn't make it up a hill, you could have someone knock the valve off with a big hammer. The extra boost ought to do it.😲
dtcerrato
Unless you own a compressor that can pump 3500 psi the only way I know to fill a SCUBA tank is at a dive shop and most if not all of them would require a SCUBA certification card. Yes knocking off the valve on a full SCUBA tank makes an awesome rocket but very hard to control... My intent would be to use it intermittently when I didn't want to fire the engine nor the Genny for building air - in that respect the tank could last a very long time. I once used a Scott Hydro Pack (1750 psi used by fire depts.) To run from the south end of the NJ turnpike to northern CT during an engine compressor failure. Tank was more than 1/2 full when I finished. It was raining but didn't run the air wipers  8)
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Toads: 2009 Jeep GC Limited 4X4 5.7L Hemi
             2008 GMC Envoy SLT 4x4 4.2L IL Vortec
uncle ned
Look for the big tank from some buses that have air starters.
They have to have a large volume
uncle ned
4104's forever
6v92 v730
Huggy Bear
Back to the fast idle,on a 4104 they are easy to setup using a 12v mini or micro servo actuator they sell for around 50 bucks. I just add a bracket on the throttle arm at the governor a little wiring with a momentary toggle switch and you are done with a system you can adjust the speed you desire
